[OpenLayers-Users] Rép. : Re: [WFS] Error insert in geoserver
Andreas Hocevar ahocevar at opengeo.org
Thu Jan 7 11:06:48 EST 2010
this looks like a GeoServer issue. Can you report that in the geoserver
users list? If not let me know, then I'll forward your message.
Regards,
Andreas.
On 2010-01-07 14:49, Patrick Mayrand wrote:
> Hi,
> my layer definition:
>         olWFSParcelle = new OpenLayers.Layer.Vector("Parcelle - WFS-T", {
>             projection: new OpenLayers.Projection("EPSG:32198"),
>             strategies: [new OpenLayers.Strategy.BBOX(), oSaveStrategy],
>             protocol: new OpenLayers.Protocol.WFS({
>                 version:       "1.1.0",
>                 url:           "http://sig.fool.qc/geoserver/wfs
> <http://mrsig.fadq.qc/geoserver/wfs>",
>                 featureType:   "SAGR_V3",
>                 srsName:       "EPSG:32198",
>                 featurePrefix:  "fadq",
>                 featureNS:     "http://sig.fool.qc/fadq
> <http://mrsig.fadq.qc/fadq>",
>                 geometryName:  "GEOM",
>                 schema:        "http://sig.fool.qc/geoserver/
> <http://mrsig.fadq.qc/geoserver/wfs/DescribeFeatureType?version=1.1.0&srsName=EPSG:32198&TypeName=fadq:SAGR_V3>wfs?service=WFS&version=1.1.0&request=DescribeFeatureTyp&srsName=EPSG:32198&typename=faqd:SAGR_V3
> <http://path/to/geoserver/wfs?service=WFS&version=1.1.0&request=DescribeFeatureTyp&typename=faqd:SAGR_V3>"
> >>> Andreas Hocevar <ahocevar at opengeo.org> 01/07/10 3:26 am >>>
> Hi,
> I do not see how the request below would make any difference if the
> order was changed. According to the schema, the Transaction children are
> a 0..* choice, not a sequence.
> Can you please also paste the server response to the failing transaction
> request?
> Regards,
> Andreas.
> The only problem I see with the xml you pasted is that the
> On 2010-01-06 22:34, Patrick Mayrand wrote:
> > Hi,
> > with OL i use the edition of polygon. A transaction with several
> > operation does not work
> > GML generate by Openlayers:
> > <wfs:Transaction xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> > version="1.1.0"
> > xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
> <http://schemas.opengis.net/wfs/1.1.0/wfs.xsd%22>
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> > <wfs:Delete typeName="fadq:SAGR_V3"
> > xmlns:fadq="http://sig.fool.qc/fadq"><ogc:Filter (
> > 'http://mrsig.fadq.qc/fadq" )
> > xmlns:ogc="http://www.opengis.net/ogc"><ogc:FeatureId (
> > 'http://www.opengis.net/ogc" )
> > fid="SAGR_V3.17"/></ogc:Filter></wfs:Delete>
> > <wfs:Insert><feature:SAGR_V3
> xmlns:feature="http://sig.fool.qc/fadq"><feature:GEOM><gml:MultiSurface (
> > 'http://sig.fool.qc/fadq" ) xmlns:gml="http://www.opengis.net/gml"
> srsName="EPSG:32198"><gml:surfaceMember><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList>-206413.01818846
> > 292765.09570319 -206182.22900389 292089.51281744 -205745.8276367
> > 292269.94799811 -205917.87048338 292479.75634772 -206413.01818846
> 292765.09570319</gml:posList></gml:LinearRing></gml:exterior></gml:Polygon></gml:surfaceMember></gml:MultiSurface></feature:GEOM></feature:SAGR_V3></wfs:Insert>
> > </wfs:Transaction>
> > The order is:
> > DELETE - INSERT
> > but the order should be reversed and it works
> > INSERT - DELETE
> > It this normal?? a bug??
> > regards,
> > Pat
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
Andreas Hocevar
