[OpenLayers-Users] Problems with SLD_BODY
fsalasGeocuba fsalas at geocuba.cu
Thu Jan 7 17:48:15 EST 2010
I´m trying to apply one new style to point layer using for that the property
SLD_BODY.
For do this operation I do with my own rules one StyledLayerDescriptor but
here is the problem, when hay try to put
more of six rules, no drawing me the layer. My questions is.
There are rulers´s limits for SLD_BODY?
Example:
function Change_Styles()
map.layers[0].params.SLD_BODY = '<StyledLayerDescriptor
version="1.0.0"><UserLayer><Name>topp:sennal</Name><UserStyle><Name>UserSelection</Name><FeatureTypeStyle><Rule><Filter
xmlns:gml="http://www.opengis.net/gml"><And><PropertyIsEqualTo><PropertyName>tipo_senal</PropertyName><Literal>FV</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>ciega_luminica</PropertyName><Literal>L</Literal></PropertyIsEqualTo></And></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
xlink:href="file:/D:/AppServ/www/SIGANAV/images/FFENFL.png"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer></Rule><Rule><Filter
xmlns:gml="http://www.opengis.net/gml"><And><PropertyIsEqualTo><PropertyName>tipo_senal</PropertyName><Literal>FA</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>ciega_luminica</PropertyName><Literal>L</Literal></PropertyIsEqualTo></And></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xmlns:gml="http://www.opengis.net/gml"><And><PropertyIsEqualTo><PropertyName>tipo_senal</PropertyName><Literal>ENF</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>ciega_luminica</PropertyName><Literal>L</Literal></PropertyIsEqualTo></And></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xmlns:gml="http://www.opengis.net/gml"><And><PropertyIsEqualTo><PropertyName>tipo_senal</PropertyName><Literal>ENF</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>ciega_luminica</PropertyName><Literal>C</Literal></PropertyIsEqualTo></And></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xlink:href="file:/D:/AppServ/www/SIGANAV/images/ENFC.png"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer></Rule><Rule><Filter
xmlns:gml="http://www.opengis.net/gml"><And><PropertyIsEqualTo><PropertyName>tipo_senal</PropertyName><Literal>BZ</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>ciega_luminica</PropertyName><Literal>L</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>color</PropertyName><Literal>Verde</Literal></PropertyIsEqualTo></And></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xlink:href="file:/D:/AppServ/www/SIGANAV/images/BZL-V.png"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer></Rule><Rule><Filter
<PropertyIsEqualTo><PropertyName>color</PropertyName><Literal>Roja</Literal></PropertyIsEqualTo></And></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xlink:href="file:/D:/AppServ/www/SIGANAV/images/BZL-R.png"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer></Rule><Rule><Filter
xmlns:gml="http://www.opengis.net/gml"><And><PropertyIsEqualTo><PropertyName>tipo_senal</PropertyName><Literal>BZ</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>ciega_luminica</PropertyName><Literal>L</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>color</PropertyName><Literal>Amarilla</Literal></PropertyIsEqualTo></And></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xlink:href="file:/D:/AppServ/www/SIGANAV/images/BZL-A.png"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer></Rule></FeatureTypeStyle></UserStyle></UserLayer></StyledLayerDescriptor>';
//map.layers[0].params.SLD_BODY = '<StyledLayerDescriptor
xmlns:gml="http://www.opengis.net/gml"><And><PropertyIsEqualTo><PropertyName>tipo_senal</PropertyName><Literal>BZ</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>ciega_luminica</PropertyName><Literal>C</Literal></PropertyIsEqualTo><PropertyIsEqualTo><PropertyName>color</PropertyName><Literal>Amarilla</Literal></PropertyIsEqualTo></And></Filter><PointSymbolizer><Graphic><ExternalGraphic><OnlineResource
xlink:href="file:/D:/AppServ/www/SIGANAV/images/BZC-A.png"/><Format>image/gif</Format></ExternalGraphic><Opacity><Literal>1.0</Literal></Opacity><Size><Literal>20.0</Literal></Size><Rotation><Literal>0.0</Literal></Rotation></Graphic></PointSymbolizer></Rule></FeatureTypeStyle></UserStyle></UserLayer></StyledLayerDescriptor>';
map.layers[0].redraw();
Greetings Salas
