[OpenLayers-Users] line modify crashes safari
Christopher Schmidt crschmidt at metacarta.com
Fri Jan 8 10:55:31 EST 2010
On Fri, Jan 08, 2010 at 04:16:55PM +0100, Andreas Hocevar wrote:
> Hi,
> thanks for your report Chris.
> Christopher Schmidt wrote:
>> When opening snapping.html, I see no geometries anymore.
> Are you sure? I tried with all webkit browsers available to me (Safari
> on Windows, Epiphany-webkit and Chromium on Linux) and the geometries
> look just fine.
> /me really hopes that this was just due to remainders of unpatched code
> in the browser cache or something, otherwise I have no idea for further
> workarounds because I cannot reproduce this.
Just me being a fool and running from file:; can confirm that it works fine.
>> When drawing a geometry, I see:
>> TypeError: Result of expression 'target.parentNode' [null] is not an object.
>> many times as I drag along a snapping edge.
> I was able to fix this one and attached a new patch to the ticket.
Confrimed that the patch works.
Regards,
Christopher Schmidt
MetaCarta
