[OpenLayers-Users] WMS format image/gif and opacity from SLD
Andreas Hocevar ahocevar at opengeo.org
Sat Jan 9 02:55:19 EST 2010
Dragan Podvezanec wrote:
> Is it normal that opacity parameter from SLD is ignored while trying to use
> GIF image format (WMS layer from geoserver)?
> With PNG it works well, but PNG's are simply too large when having 20 or
> more WMS layers on the map.
Opacity in SLD requires Alpha transparency, which is only available for
PNG. IIRC there are ways to have Alpha with 8-bit PNG, which would give
you images with about the same size as GIF. Look in the docs of your WMS
for details on how to configure that.
Another option would be to pack all your layers into one
OpenLayers.Layer.WMS, instead of using separate ones. So let's say your
WMS has layers called layer1, layer2 and layer3, then your WMS layer
would look like this:
var layer = OpenLayers.Layer.WMS("my layers", "path/to/my/wms", {
    layers: ["layer1", "layer2", "layer3"]
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
