[OpenLayers-Users] Opacity of GoogleLayer, get selected layer
Eric Lemoine eric.lemoine at camptocamp.com
Thu Jan 14 02:34:28 EST 2010
On Wed, Jan 13, 2010 at 7:05 PM, Dirk Tanneberger
<dirk.tanneberger at unibas.ch> wrote:
> Hi everybody,
Hi
> I'm using Openlayers within MapFish. But I think the issue is specific
> to Openlayers, so I post it here. Hope somebody got a clue.
> What I'm trying to do is: applying a opacity to a Google-Layer with the
> "setOpacity"-method.
> Here is the code I'm using:
>    var options = {
>            projection: new OpenLayers.Projection("EPSG:900913"),
>            displayProjection: new OpenLayers.Projection("EPSG:4326"),
>            units: "m",
>            numZoomLevels: 18,
>            maxResolution: 156543.0339,
>            maxExtent: new OpenLayers.Bounds(810690, 6027000,
>                                                883240, 6118400),
>            controls: []
>    var map = new OpenLayers.Map(options);
>    var google = new OpenLayers.Layer.Google(
>            "Google",
>            {'sphericalMercator': true}
>    var OSM = new OpenLayers.Layer.OSM("OSM");
>    var google_t = new OpenLayers.Layer.Google(
>                "Google_Terrain",
>                {type: G_PHYSICAL_MAP, 'sphericalMercator': true}
>    google.setOpacity(0.5);
>    map.addLayers([google, OSM, google_t]);
> It works fine for th OSM-layer (if specified), but either one of the
> Google-layers won't take the opacity. They just show up in full bright.
> Has anybody experienced similar?
No. I just opened
<http://openlayers.org/dev/examples/spherical-mercator.html> and
entered map.baseLayer.setOpacity(0.2) in the FireBug console and the
Google layer's opacity did change. Do you have a live example showing
the problem?
> Another question is: How can I obtain the selected Layer from the map?
map.baseLayer may be what you're looking for.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
