[OpenLayers-Users] writing and saving text and then displaying it as a wfs layer
Alauddin Khan akhan at pakvistatech.com
Fri Jan 15 01:47:50 EST 2010
thank you so much for ur help alexander i am saving text successfully now
but when i try to display it again through a browser it is nt displayed .i
can view it through geoserver map preview but not through browser . i think
the problem is tht openlayers associate its own style with the layer and not
the default sld tht is associated with the feature type in geoserver  (i-e
capitals.sld).how can i give my layer custom sld ( the sld tht was
associated with it in geoserver).??
On Wed, Jan 13, 2010 at 11:32 AM, Alauddin Khan <akhan at pakvistatech.com>wrote:
> hi
> i got some idea about what to do now . but problem is can i pass a variable
> as an attirbute to wfs layer ?? i mean i want to pass as an attribute
> variable (style_text.label) which contains text tht i am getting. can it b
> done ??and how ?
> thanks
> On Mon, Jan 11, 2010 at 7:01 PM, Alexandre Dube <adube at mapgears.com>wrote:
>> Alauddin,
>>  Please, reply to the list as many other might be able to help you.
>>  Please, take a look at the following example [1].  In it, you have a
>> vector layer configured to a WFS-T server to allow transactions.  OpenLayers
>> is responsible of generating the transaction by AJAX on commit.  Look at the
>> code of the example for more.
>>  If it can help, I also made a WFS-T little demo a year ago.  The
>> OpenLayers version is outdated, but it might help too [2].  It uses TinyOWS
>> as the WFS-T server (instead of GeoServer) though.
>>  Hope it helps,
>> Alexandre
>> [1] http://openlayers.org/dev/examples/wfs-protocol-transactions.html
>> [2] http://dev4.mapgears.com/bdga/bdgaWFS-T.html
>> Alauddin Khan wrote:
>>> sorry i am new to mapping and this openlayers geoserver thing so i could
>>> not pick up wht u r saying what i really want is to let user write nething
>>> i-e label comment joke etc etc on the  map displayed nd then save it,  add
>>> it to database and latter on same text as displayed as a wfs layer . i mean
>>> map is displayed as wms layer then we hav 3 layers  for point line and
>>> polygon giving user capability to draw line polygon or point and save it now
>>> i want to add another layer named as text layer which enables to write on
>>> the map ne comments note or label etc which is u kno then saved can i do
>>> this with open layers ? Mr imran rajjad from geoserver list suggested me
>>> below four point strategy which i could not follow up completly his
>>> suggestion was
>>> 1-create a shape file with point geometry and upload it on geoserver,make
>>> sure you keep a field in the attributes for your label.
>>> 2-write a function that takes  X,Y of click and the text you wish to
>>> display
>>> 3-insert that point where you clicked on map along with the text into the
>>> shape file          4-create an SLD for this shape file in which you add
>>> text symbolizer and set it to display the field containing you label.
>>>  but i got stuck at point 3 .dont know how to move things forward. please
>>> help thanks
>>> Regards
>>> Alauddin
>>> On Fri, Jan 8, 2010 at 6:28 PM, Alexandre Dube <adube at mapgears.com<mailto:
>>> adube at mapgears.com>> wrote:
>>>    Hi,
>>>     Take a look at this example [1].  Labels are added to features as
>>>    symbolizer properties, so you could set one of the feature's
>>>    attribute as a value for your label by using ${name} (see the same
>>>    example).
>>>     Hope this helps,
>>>    Alexandre
>>>    [1] http://openlayers.org/dev/examples/vector-features-with-text.html
>>>        hi ALL ,
>>>                  hop u all fin and in good health. i want to  write
>>>        text on my map ( may b some information about a place) and
>>>        then save it so that next time i use my map the text is
>>>        visible there . i know u can use wfs to add new features but
>>>        how will i add text as a new wfs layer in geoserver
>>>        thanks
>>>        Regards
>>>        Alauddin
>>>        _______________________________________________
>>>        Users mailing list
>>>        Users at openlayers.org <mailto:Users at openlayers.org>
>>>        http://openlayers.org/mailman/listinfo/users
>>>    --    Alexandre Dubé
>>>    Mapgears
>>>    www.mapgears.com <http://www.mapgears.com>
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100115/a1727b62/attachment.html
