[OpenLayers-Users] Opacity of GoogleLayer, get selected layer
Arnd Wippermann arnd.wippermann at web.de
Fri Jan 15 12:08:34 EST 2010
    OSM.setOpacity(0.1);
    map.addLayers([google, OSM, google_t]);
    google.setOpacity(0.1);
    google_t.setOpacity(0.1);
The Google layers have to add to the map before you can change the opacity
of the Google layers. For other layers it's possible before adding them to
the map.
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Eric Lemoine
Gesendet: Freitag, 15. Januar 2010 17:21
An: Dirk Tanneberger
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Opacity of GoogleLayer, get selected layer
On Fri, Jan 15, 2010 at 12:05 PM, Dirk Tanneberger
<dirk.tanneberger at unibas.ch> wrote:
> Hi Eric,  thanks for the fast reply.
> With the baseLayer-object it works. I tried to apply the method
> directly to the layer, maybe that was the problem.
> But still I have the problem, when changing the baseLayer. In my case
> I got three baseLayers and no matter which one is selected it should
> have a opacity.
> If I do it like this:
> var map = new OpenLayers.Map(options);
>     var google = new OpenLayers.Layer.Google(
>             "Google",
>             {'sphericalMercator': true}
>     var OSM = new OpenLayers.Layer.OSM("OSM");
>     var google_t = new OpenLayers.Layer.Google(
>                 "Google_Terrain",
>                 {type: G_PHYSICAL_MAP, 'sphericalMercator': true}
>     map.addLayers([OSM, google, google_t]);
>     map.baseLayer.setOpacity(0.5);
> the opacity is applied just to the initial baseLayer. The other layers
> don't have a opacity after being selected.
> I think, thats why I have to trigger the event, wether a layer is
> selected or not and set the opacity afterwards.
> Maybe it is possible to do so in the treepanel-object of the mapFish-API.
> Couldn't find anything appropriate so far, but I have to dig more into it.
> If you or somebody else got a hint, I would appreciate it very much.
<http://www.openlayers.org/dev/examples/spherical-mercator.html>
open the firebug console, and do:
map.layers[0].setOpacity(0.2) // -> this changes the opacity of the current
base layer
map.layers[1].setOpacity(0.2) // -> this changes the opacity of the Google
Satellite layer, although it's not the current base layer
now select the Google Satellite layer in the LayerSwitcher, its opacity is
expectedly 0.2.
Maybe I don't understand the issue you're having.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
