[OpenLayers-Users] writing and saving text and then displaying it as a wfs layer
Alauddin Khan akhan at pakvistatech.com
Thu Jan 21 00:24:57 EST 2010
can i get an example of wfs layer i mean in which they hav used wfs layer
instead of wms can i associate geoserver sld to render features in wfs layer
all the example i searched on the net uses wms can it b done using wfs ??
On Fri, Jan 15, 2010 at 6:25 PM, Alexandre Dube <adube at mapgears.com> wrote:
> Alauddin,
>  I'm not sure.  Did you take a look at these examples [1] [2].  I guess it
> could help.
>  Regards,
> Alexandre
> [1] http://openlayers.org/dev/examples/sld.html
> [2] http://openlayers.org/dev/examples/WMSPost.html
> Alauddin Khan wrote:
>> thank you so much for ur help alexander i am saving text successfully now
>> but when i try to display it again through a browser it is nt displayed .i
>> can view it through geoserver map preview but not through browser . i think
>> the problem is tht openlayers associate its own style with the layer and not
>> the default sld tht is associated with the feature type in geoserver  (i-e
>> capitals.sld).how can i give my layer custom sld ( the sld tht was
>> associated with it in geoserver).??
>> On Wed, Jan 13, 2010 at 11:32 AM, Alauddin Khan <akhan at pakvistatech.com<mailto:
>> akhan at pakvistatech.com>> wrote:
>>    hi
>>    i got some idea about what to do now . but problem is can i pass a
>>    variable as an attirbute to wfs layer ?? i mean i want to pass as
>>    an attribute variable (style_text.label) which contains text tht i
>>    am getting. can it b done ??and how ?
>>    thanks
>>    On Mon, Jan 11, 2010 at 7:01 PM, Alexandre Dube
>>    <adube at mapgears.com <mailto:adube at mapgears.com>> wrote:
>>        Alauddin,
>>         Please, reply to the list as many other might be able to help
>>        you.
>>         Please, take a look at the following example [1].  In it, you
>>        have a vector layer configured to a WFS-T server to allow
>>        transactions.  OpenLayers is responsible of generating the
>>        transaction by AJAX on commit.  Look at the code of the
>>        example for more.
>>         If it can help, I also made a WFS-T little demo a year ago.
>>         The OpenLayers version is outdated, but it might help too
>>        [2].  It uses TinyOWS as the WFS-T server (instead of
>>        GeoServer) though.
>>         Hope it helps,
>>        Alexandre
>>        [1]
>>        http://openlayers.org/dev/examples/wfs-protocol-transactions.html
>>        [2] http://dev4.mapgears.com/bdga/bdgaWFS-T.html
>>            sorry i am new to mapping and this openlayers geoserver
>>            thing so i could not pick up wht u r saying what i really
>>            want is to let user write nething i-e label comment joke
>>            etc etc on the  map displayed nd then save it,  add it to
>>            database and latter on same text as displayed as a wfs
>>            layer . i mean map is displayed as wms layer then we hav 3
>>            layers  for point line and polygon giving user capability
>>            to draw line polygon or point and save it now i want to
>>            add another layer named as text layer which enables to
>>            write on the map ne comments note or label etc which is u
>>            kno then saved can i do this with open layers ? Mr imran
>>            rajjad from geoserver list suggested me below four point
>>            strategy which i could not follow up completly his
>>            suggestion was
>>            1-create a shape file with point geometry and upload it on
>>            geoserver,make sure you keep a field in the attributes for
>>            your label.
>>            2-write a function that takes  X,Y of click and the text
>>            you wish to display
>>            3-insert that point where you clicked on map along with
>>            the text into the shape file          4-create an SLD for
>>            this shape file in which you add text symbolizer and set
>>            it to display the field containing you label.
>>             but i got stuck at point 3 .dont know how to move things
>>            forward. please help thanks
>>            Regards
>>            Alauddin
>>            On Fri, Jan 8, 2010 at 6:28 PM, Alexandre Dube
>>            <mailto:adube at mapgears.com <mailto:adube at mapgears.com>>>
>>            wrote:
>>               Hi,
>>                Take a look at this example [1].  Labels are added to
>>            features as
>>               symbolizer properties, so you could set one of the
>>            feature's
>>               attribute as a value for your label by using ${name}
>>            (see the same
>>               example).
>>                Hope this helps,
>>               Alexandre
>>               [1]
>> http://openlayers.org/dev/examples/vector-features-with-text.html
>>                   hi ALL ,
>>                             hop u all fin and in good health. i want
>>            to  write
>>                   text on my map ( may b some information about a
>>            place) and
>>                   then save it so that next time i use my map the text is
>>                   visible there . i know u can use wfs to add new
>>            features but
>>                   how will i add text as a new wfs layer in geoserver
>>                   thanks
>>                   Regards
>>                   Alauddin
>>                   _______________________________________________
>>                   Users mailing list
>>                   Users at openlayers.org <mailto:Users at openlayers.org>
>>            <mailto:Users at openlayers.org <mailto:Users at openlayers.org>>
>>                   http://openlayers.org/mailman/listinfo/users
>>               --    Alexandre Dubé
>>               Mapgears
>>               www.mapgears.com <http://www.mapgears.com>
>>        --        Alexandre Dubé
>>        Mapgears
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100121/fb189d59/attachment.html
