[OpenLayers-Users] Problem with WFS/Popups in Firefox
Rauch, Barbara rauch at rvr-online.de
Thu Jan 21 10:25:29 EST 2010
Hello again,
we just found another hint concerning the error in IE:
Meldung: Unbekannter Fehler.
Zeile: 81
Zeichen: 9
Code: 0
URI: http://217.78.131.132/dev_ol/ol_print/mfbase/openlayers/lib/OpenLayers/Renderer/VML.js
I will now in a first step compare the VML.js from OpenLayers Version 2.7 and 2.8 and perhaps link to 2.8 to test, if the error still occurs. In the moment, the client is linked to version 2.7
Thanks for any other hint/idea
Barbara
Hi Barbara,
no, not only green symbols made problems. Other time the red one made problems. Popups opened sometimes near the symbols/marker but were sometimes about a few centimeters away.
IE gave me a white map. And confirm the strange behaviour of map being there after going to another page. Think its a IE problem (IE can´t find a variable, map or something else). But I don´t have any further ideas how to solve this, sorry.
best regards
Sarah
Von: "Rauch, Barbara" <rauch at rvr-online.de>
An: Sarah Schuessler <sarah_flip at yahoo.de>; Marc Jansen <jansen at terrestris.de>
CC: users at openlayers.org
Gesendet: Donnerstag, den 21. Januar 2010, 15:48:08 Uhr
Betreff: Re: [OpenLayers-Users] Problem with WFS/Popups in Firefox
Hi Sarah,
Concerning Firefox: Did you test one time or several times - if several times, always ONLY the green symbols made problems? And if, can you see, that the popups of the green symbols open directly at the symbol or is there an offset and they open somewhere in the map?
Some news about the white map when starting IE: When you start IE and the given Link is the first page you want to see, there always occurs the white map - when you then start any another page in the IE and then start the given Link to my OpenLayersClient, the map will be there. Can anybody confirm this? Has anybody any idea how to solve the problem?
Thanks a lot
Barbara
Hi Barbara,
I could confirm that my IE 8 gave me a white page.
At Firefox 3.5.7 popups only occur when clicking on the orange circles.(green gave me "searching for data").
best regards
Sarah
An: Marc Jansen <jansen at terrestris.de>
Gesendet: Donnerstag, den 21. Januar 2010, 12:49:51 Uhr
Hi List,
I now solved the database-problem that caused some popups not to be filled with information when you click on a symbol. I also checked the projection as Marc proposed, but that didn't help. I still have the problem in Firefox (and only in Firefox, it until now did never occur in IE!) that after zooming twice AND panning the map, some popups (not always the same!) have an offset and don't open directly at the symbol but somewhere else in the map.
You can see here: http://217.78.131.132/dev_ol/ol_print/ol_viewer_neu_layout_suche.html
Second problem, this time only in the Internet Explorer: Sometimes, not always, there occurs no map, the part of the map is white and empty after having startet. When you then refresh IE it works fine... It would be great, when you could test the page and give me feedback whether it occurs or not and which IE-Version you are using.
Has anybody an idea???
Thanks a lot and greetings
Barbara
Hi Barbara,
If I click on a feature located at POINT(2552356 5693550) (near
Angerhausen, South of Duisburg) I get a GetFeatureInfo-Request with the
BBOX 2546405, 5692856, 2547405, 5693856. And of course the popup is
placed at the wrong coordinates and the GFI-Request is empty.
IMO you should try to search the error in the BBOX creation-function.
Regards,
Marc
PS: I'd guess that this problem should arise in IE as well... haven't
tested though.
Rauch, Barbara wrote:
> Hello,
> I successfully implemented WFS-Layers with individual symbols by
> creating an OpenLayers feature class for each layer. These symbols are
> clickable via clickevent that opens a Popup which is filled with
> informations by a GetFeatureRequest. In Internet Explorer everything
> works fine but in Firefox I have the following problem with the popup:
> After panning the map, some of the popups do no longer open on the
> symbol but are displaced and open with an offset away from the symbol
> - that does not occur always to the same WFS but changes. The problem
> is, that the popups then also don't get the informations and there is
> no error-message in firefox (I'm working with version 3.0).
> You can see a live-demo here:
> http://services.metropoleruhr.de/ol_print/ol_viewer.html
> Does anybody know how to fix this problem?
> Thanks for your help and greetings from Marleen
> Hi Marc,
> when you start the client in Firefox, you afterwards have to zoom in
> twice, then the symbols of the overlays occur - when you then pan the
> map (drag&drop while the left mouse is pressed) and afterwards click
> on the symbols, some of the popups don't opne right at the symbol but
> displaced in the map - not always the same symbols behave like this
> and Firefox doesn't give an error-message -all that makes it very
> difficult to find the error... I hope this description helps so far?
> Thanks and greetings
> Marleen
> Hello again,
> thanks a lot for your answer, Marc.
> In the case, when the popup doesn't display any content, there is a
> 'NULL' in the database - this error will be solved in january by
> myself via the database. But I don't know, how to solve the problem
> with the displaced popups after one panned the map. You asked, how I
> obtain the clicked ccordinate. Here my source-code:
> function addClickEvent( wfslayer, typename)
> // WFS-Abfrage + Popup-Initialisierung
> //Definition der BoundingBox-Größe
> OpenLayers.Events.prototype.includeXY = true;
> wfslayer.events.register("click", map, function(e){
> // Mauspostition bestimmen
> // (konvertiert von Pixel in o.g. EPSG-Koordinaten)
> var lonlat = map.getLonLatFromPixel(e.xy);
> //alert(lonlat);
> // Toleranzwert 'delta' berechnet mit geometrischer
> // Folge: 1000*(0.5)^(zoomlevel)
> var delta = 1000 * Math.pow(0.5, map.getZoom() );
> var more = lonlat.add(delta, delta);
> var less = lonlat.add(-delta, -delta);
> var boundingbox = less.lon + "," + less.lat + "," + more.lon + "," +
> more.lat;
> //alert(boundingbox);
> // WFS-Abfrage
> var url_rvr = wfslayer.getFullRequestString({
> REQUEST: "GetFeature",
> BBOX: boundingbox,
> INFO_FORMAT: 'text/plain',
> TYPENAME: typename
> OpenLayers.loadURL(url_rvr, '', this, setHTML);
> // Popup-Initialisierung
> popup = new OpenLayers.Popup.AnchoredBubble("siteinfo", lonlat, new
> OpenLayers.Size(180, 270));
> //popup.AutoSize = true;
> popup.setContentHTML("<div id='mapinfobox'><div
> id='nodelist'></div></div>");
> popup.setOpacity(1.0);
> popup.setBackgroundColor("FFFFFF");
> popup.addCloseBox(destroy);
> map.addPopup(popup, true);
> $('nodelist').innerHTML = "Searching for data...";
> Event.stop(e);
> Do you really think, it could be a problem with the projection? I
> would in this case expect, that the popup-displacement also occurs in
> the InternetExplorer - or do the browsers handle projections in
> different ways?
> Here my source-code concerning the projection in OpenLayers:
>  //*** edit EPSG options here! ***
>            var options_31466 = {
>                projection:"EPSG:31466",
>                                scales: [250000, 50000, 15000, 10000, 5000, 2500, 1000],
>                maxExtent: new OpenLayers.Bounds(2520400, 5675000, 2638545, 5744500),
>                maxResolution: 'auto',
>                numZoomLevels: 7,
>                controls: [],
>                units: 'm'
>            map = new OpenLayers.Map('map', options_31466);
> I thought, it's enough to include the projection in this way and that
> OpenLayers then automatically does the rest?
> Do I have to include proj4 as you wrote:
> * Are you sure that your projection is set correctly? Did you
> include a pro4.js-definition for 31466?
> Proj4js.defs["EPSG:31466"] = "+proj=tmerc +lat_0=0 +lon_0=6 +k=1
> +x_0=2500000 +y_0=0 +ellps=bessel +datum=potsdam +units=m +no_defs";
> Where do I have to put the Proj4.defs?
> Thanks a lot merry christmas and greetings
> Marleen
> Mit freundlichen Grüßen
> Im Auftrag
> **Barbara Rauch***
> Klima u. Lufthygiene
> Kronprinzenstraße 35
> 45128 Essen
> Fon: +49 201 2069-399
> Fax: +49 201 2069-400
> Regionalverband Ruhr
> 45128 Essen
> Zentrale: +49 (0) 201 2069-0
> Fax: +49 (0) 201 2069-500
> www.rvr-online.de
> Postfach 10 32 64
> 45032 Essen
> Steuernummer: RVR 112/5775/0426
> USt.-ldNr.: DE 173867500
> Diese E-Mail koennte vertrauliche und/oder rechtlich geschuetzte
> Informationen enthalten.
> Wenn Sie nicht der richtige Adressat sind oder diese E-Mail
> irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender
> und vernichten Sie diese Mail.
> Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail
> sind nicht gestattet.
> This e-mail may contain confidential and/or privileged information.
> If you are not the intended recipient (or have received this e-mail in
> error) please notify the sender immediately and destroy this e-mail.
> Any unauthorised copying, disclosure or distribution of the material
> in this e-mail is strictly forbidden.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
  Dipl.-Geogr. Marc Jansen
  - Anwendungsentwickler -
  terrestris GmbH & Co. KG
  Irmintrudisstraße 17
  53111 Bonn
  Tel:    ++49 (0)228 / 96 28 99 -53
  Fax:    ++49 (0)228 / 96 28 99 -57
  Email:  jansen at terrestris.de
  Web:    http://www.terrestris.de <http://www.terrestris.de/>
  Amtsgericht Bonn, HRA 6835
  Komplementärin:  terrestris Verwaltungsgesellschaft mbH
  vertreten durch: Hinrich Paulsen, Till Adams
Users mailing list
__________________________________________________
Do You Yahoo!?
Sie sind Spam leid? Yahoo! Mail verfügt über einen herausragenden Schutz gegen Massenmails.
http://mail.yahoo.com
Do You Yahoo!?
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100121/782da6f6/attachment.html
