[OpenLayers-Users] Refresh marker without refreshing whole map
jbloc1878 at googlemail.com jbloc1878 at googlemail.com
Tue Jan 26 03:58:07 EST 2010
Thanks for the reply.
Yes I am pulling the coordinates from a csv file using php. However I
removed my php code before emailing as it looked a but confusing.
On 25 Jan 2010, at 22:48, Nathan Gerber <ngerber999 at gmail.com> wrote:
> Your coordinates appear to be hardcoded into the HTML. If you want
> the location to change you will need to pull the coordinates in
> through the server itself through a WFS or some other server based
> layer.
> Nathan Gerber
> On Mon, Jan 25, 2010 at 5:05 PM, <jbloc1878 at googlemail.com> wrote:
> Hi,   i am currently using OS Open Space which i believe is similer
> to Open Layers.
> I am currenty displaying a map with a marker. However my marker
> coordinates can change whilst the user is viewing the map so i would
> like the Marker code to refresh and re-plot the marker every 10
> seconds however i cannot work out how to do this. I have tried
> adding aHTML refresh command <meta http-equiv="refresh"
> content="10"> causes the whole map to refresh.
> I tried creating a refresh function that calls the marker function i
> created that plots the marker as shown below. however the marker
> looks like it refreshes as the marker flashes every 10 seconds
> however it does not replot if the coordinates if they have changed.
> Does anyone have any suggestions for refreshing a function within
> javascript?
> Thanks for any help in advance my code is below
> <script type="text/javascript">
> var osMap;
> function init()
> osMap = new OpenSpace.Map('map');
> osMap.setCenter(new OpenSpace.MapPoint(439300, 114760), 8);
> function refresh()
> setInterval('marker()', 10000);
> function marker()
> var markers = new OpenLayers.Layer.Markers("Markers");
> osMap.addLayer(markers);
> // Default icon
> var pos = new OpenSpace.MapPoint(438760, 114760);
> var marker = new OpenLayers.Marker(pos);
> markers.addMarker(marker);
> </script>
> </head>
> <body onload="init(); refresh()">
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100126/fa41a045/attachment.html
