[OpenLayers-Users] Request with wrong column name
Luís de Sousa luis.a.de.sousa at gmail.com
Wed Jan 27 10:46:19 EST 2010
Hello Gabriel,
Thank you for your reply. I add the geometryName property to the WFS
constructor; it now is:
wfs = new OpenLayers.Layer.WFS(
                "Tanques",
                "/geoserver/wms",
                {typename: 'insaar:M_TANQUE',
                 srs: 'EPSG:82176'
                    typename: "M_TANQUE",
                    featureNS: "http://insaar.inag.pt",
                    geometryName: "shape",
                    commitReport: function() {
                    extractAttributes: true,
This had no effect, in the request the feature is still identified with
"the_geom". I could change the column name in the database, but would prefer
some workaround with the code.
Thanks,
Luís
On Tue, Jan 26, 2010 at 10:12 PM, Gabriel Nolasco <
nolasco_gabriel at yahoo.com.br> wrote:
> Hello Luis,
> If you are using a vector layer with a WFS protocol you can use the
> property 'geometryName' to set the name of the geometry column.  Default is
> 'the_geom'[1]
> You can see an example of the WFS protocol usage at OpenLayers examples
> page [2]
> [1]
> http://dev.openlayers.org/docs/files/OpenLayers/Protocol/WFS/v1-js.html#OpenLayers.Protocol.WFS.v1.geometryName
> [2] http://openlayers.org/dev/examples/wfs-protocol-transactions.html
> Best regards,
> Gabriel Nolasco
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100127/3b70fa52/attachment.html
