[OpenLayers-Users] Towards an eraser tool in OpenLayers
Atle Frenvik Sveen atle.frenvik.sveen at geomatikk.no
Wed Jan 27 11:00:47 EST 2010
Hmm, I think your proposal looks overly complicated. Why don't just
remove the feature from the layer it is drawn on?
And possibly store it somewhere else if you want to regret the deletion?
Or am I misunderstanding you here?
-atle
On Wed, 2010-01-27 at 12:28 +0000, Dan Garland wrote:
> Any takers? Or am I on the wrong track here?
> Thanks in advance,
> Dan
> Dan Garland wrote:
> > Hi all,
> > I'm a Ruby on Rails developer working on my first project with
> > OpenLayers. I'm tasked with developing an free-hand eraser tool that can
> > erase features created by the drawFeatures tool. Amongst other things
> > we've tried, my thinking is moving towards creating a SVG mask, based on
> > the existing drawing tool, in which the 'erased' line is actually a
> > black line within a white, rectangular SVG mask, which when applied over
> > the top of the tile layer would mask any drawn features from underneath.
> > I anticipate something like this:
> > <svg width="8cm" height="8cm" viewBox="0 0 800 800" version="1.1"
> >       xmlns="http://www.w3.org/2000/svg"
> > xmlns:xlink="http://www.w3.org/1999/xlink">
> >    <defs>
> >      <mask id="Mask" maskUnits="userSpaceOnUse" x="0" y="0" width="3968"
> > height="2964">
> >        <rect x="0" y="0" width="3968" height="2964" fill="white" />
> >        <!-- The 'eraser' line -->
> >        <polyline fill="none" stroke="black" stroke-width="25"
> > points="400,0 400,800" />
> >      </mask>
> >    </defs>
> > <!-- Example drawn features -->
> >    <polyline id="myline" points="0,0 800,800" fill="none"
> > stroke-opacity="1" stroke-width="25" stroke-linecap="round"
> > stroke-linejoin="round" stroke-dasharray="none"/>
> >    <polyline id="myline2" points="0,100 800,100" fill="none"
> >    <polyline id="myline3" points="0,400 800,400" fill="none"
> >     <use xlink:href="#myline" stroke="red" mask="url(#Mask)" />
> >     <use xlink:href="#myline2" stroke="red" mask="url(#Mask)" />
> >     <use xlink:href="#myline3" stroke="red" mask="url(#Mask)" />
> > </svg>
> > The problems I face with this approach is knowing how best to manipulate
> > the existing SVG object being referenced by OpenLayers. I wonder whether
> > it is feasible in OpenLayers to develop a control based on the
> > drawFeature tool that
> > 1) Adds the mask <defs> section to the SVG Root at startup
> > 2) Creates polyline elements with the mask
> > 3) Adds <use> elements for each element in the tile layer to connect the
> > id and the mask
> > Before I dive in and spent hours in an unfamiliar area I wonder if any
> > OpenLayers developers have encountered this use case and have a better
> > solution, or can shed any light on this proposed approach.
> > Best Regards,
> > Dan Garland
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Users mailing list
Atle Frenvik Sveen
Geomatikk IKT AS
tel: 45 27 86 89
mail. atle.frenvik.sveen at geomatikk.no
