[OpenLayers-Users] map.setCenter fails
Eric Lemoine eric.lemoine at camptocamp.com
Fri Jan 29 07:11:08 EST 2010
On Friday, January 29, 2010, Dirk Tanneberger
<dirk.tanneberger at unibas.ch> wrote:
> I forgot to say, that i use a GeoExt mappanel, in which i put the map.
> I assume the mappanel config overrides the openlayers-map-config. And
> since there is no center and zoom set in the panel config, it just
> shows the whole world. Right?
> So is there a way to keep the map-config? Because i want to dynamically
> change the map-zoom and center, when the user selects a special layer.
> But the mappanel shouldn't change.
> The code for the mappanel (it's part of an ext viewport):
>                 title: 'Karte',
>                 xtype: 'gx_mappanel',
>                 map: map,
>                 border: false,
>                 region: 'center'
Hi. This is a GeoExt question, so I'd suggest taking the question to
the GeoExt users mailing list. You have more chance to get answers
there.
Cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
