[OpenLayers-Users] select feature control not working
Andreas Hocevar ahocevar at opengeo.org
Thu Jun 3 08:07:10 EDT 2010
No, if you host your application off GeoServer it is better to place a full version in the www folder of your data dir and not touch the one that is included.
-Andreas.
On Jun 3, 2010, at 13:53 , Imran Rajjad wrote:
> All right and I replace the js file in geoserver directory with the
> new downloaded? will that be ok?
> On Thu, Jun 3, 2010 at 4:52 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
>> Hi,
>> the OpenLayers versions that ship with GeoServer only include the functionality that is needed for the GeoServer layer preview. Please download a full version from http://openlayers.org
>> Regards,
>> Andreas.
>> On Jun 3, 2010, at 13:46 , Imran Rajjad wrote:
>>> thanks for your reply
>>> I`m using the one that comes with geoserver 1.7.7 . not too sure about
>>> the version. But the select and highlight works. When I tried the code
>>> on my page.. only the highlight control was working with a highlight
>>> color different from the one in example. Later through console i
>>> deactivated the highlight control and then activated the select
>>> control .. then the select control started working .. the events are
>>> also getting triggered.i was hoping to get to the attributes of the
>>> feature clicked at.
>>> On Thu, Jun 3, 2010 at 4:31 PM, Eric Lemoine
>>> <eric.lemoine at camptocamp.com> wrote:
>>>> On Thu, Jun 3, 2010 at 12:01 PM, Imran Rajjad <rajjad at gmail.com> wrote:
>>>>> I`m trying to run a function on clicking and highlighting of a vector
>>>>> layer. the events do not seem to trigger..
>>>>> what am i doing wrong here?
>>>>> my code
>>>>> var report = function(e) { // it will be called when event is trigered
>>>>> from eventListeners
>>>>>                console.log(e.type, e.feature.id);
>>>>>                //alert(e.feature.id);
>>>>>            var highlightCtrl = new
>>>>> OpenLayers.Control.SelectFeature(vector_layer, {
>>>>>                hover: true,
>>>>>                highlightOnly: true,
>>>>>                renderIntent: "highlight",
>>>>>                eventListeners: {
>>>>>                    beforefeaturehighlighted: report,
>>>>>                    featureunhighlighted: report
>>>>>            var selectCtrl = new OpenLayers.Control.SelectFeature(vector_layer,
>>>>>                {clickout: true}
>>>>>            map.addControl(highlightCtrl); // add high lighting
>>>>>            map.addControl(selectCtrl); // add selection
>>>>>            highlightCtrl.activate();
>>>>>            selectCtrl.activate();
>>>> What OpenLayers version do you use? Does the highlight-feature.html
>>>> example of your OpenLayers distribution work?
>>>> Cheers,
>>>> Eric Lemoine
>>>> Camptocamp France SAS
>>>> Savoie Technolac, BP 352
>>>> 73377 Le Bourget du Lac, Cedex
>>>> Tel : 00 33 4 79 44 44 96
>>>> Mail : eric.lemoine at camptocamp.com
>>>> http://www.camptocamp.com
>>> I.R
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
> I.R
Andreas Hocevar
