[OpenLayers-Users] Does anyone have the projection definitions for all EPSG codes in Proj4js format?
P Kishor punk.kish at gmail.com
Sun Jun 6 10:51:14 EDT 2010
On Fri, Jun 4, 2010 at 6:17 PM, Vadim Bokin <vbokin at gmail.com> wrote:
> My map viewer is using Proj4js for re-projection and I know that it goes out
> to http://spatialreference.org/ to get definitions that are not yet known to
> OpenLayers through the /def/*.js files.
> However, I know that my map client will be used on local network w/o any
> internet connectivity.  It'll be connected to a map server on the LAN and
> the base map can be in whatever projection, not just WGS84 or Mercator.
> Data layers will come from the same LAN.
> The map viewer is already built to support "any" projection as long as the
> definition is known and the map client performs all necessary on-the-fly re
> projections for vector data.
> However, in this stand-alone environment, there is no access to Spatial
> Reference website.
> So I was wondering - does anyone have a JavaScript file - e.g. EPSG.js -
> that has all of the definitions, or say "a lot" of definitions preloaded
> ahead of time that I could load into OL at start up?
> I'm thinking of a single file with a bunch of definitions
> Proj4js.defs["EPSG:1111"] = "...;
> Proj4js.defs["EPSG:2222"] = "...;
> Or a zip file of individual files for all the WKIDs
> e.g.
> EPSG1111.js, EPSG2222.js, and so on.
> Or perhaps someone from http://spatialreference.org/ here could comment if a
> data-dump is available from your site?
I have a bunch on my web site that you might find useful to start with
See http://punkish.org/140
> Thank you.
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Does-anyone-have-the-projection-definitions-for-all-EPSG-codes-in-Proj4js-format-tp5141431p5141431.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Puneet Kishor http://www.punkish.org
Carbon Model http://carbonmodel.org
Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
Nelson Institute, UW-Madison http://www.nelson.wisc.edu
Assertions are politics; backing up assertions with evidence is science
