[OpenLayers-Users] Options for fighting the 180 degree problem - any server able to do it? Other approaches?
Ian Turton ijturton at gmail.com
Tue Jun 8 10:28:39 EDT 2010
On Mon, Jun 7, 2010 at 7:04 PM, Phil Scadden <p.scadden at gns.cri.nz> wrote:
> Okay. I really have to get around the 180 problem.
> Here is the issue:
> I have line and polygon data that crosses the 180 line. Now with some
> projections, both geoserver and ESRI ArcGIS Server can map these
> successfully. However, the moment you want to use Google map data you
> are in trouble. I can find no way to persuade either system to deliver
> lines and polygon data crossing the 180 with the google spherical
> mercator. ESRI have more or less indicated that they dont care.
> Geoserver says it would take a rewrite of their render.
Which was completed some time back - see
http://blog.geoserver.org/2010/02/23/geoserver-map-wrapping/ for
details.
Ian
Ian Turton
