[OpenLayers-Users] GeoExt + OpenLayers: WMSGetCapabilities->WMS layering onto OSM
Zoran Jankovic zoran.m.jankovic at gmail.com
Wed Jun 16 12:15:10 EDT 2010
OK, here is how I defined my WMS layer that I'm showing on top of Gmaps. The
key is to define "srs" parameter to Geoserver. In my case this is a custom
projection that can be defined in epsg.properties
 var tiled = new OpenLayers.Layer.WMS("ulice_kutina - Tiled", "
http://89.164.44.84/geoserver/wms",
                   layers: 'zoran:ulice',
                   styles: '',
                   srs: '222222',
                   format: 'image/png',
                   tiled: 'true',
                   transparent: true
                    'opacity': 1, 'isBaseLayer': false, 'wrapDateLine': true
I also set up custom displayProjection, but for that I had to employ
Proj4js-compressed.js (thanks Mike Adair!).
Google displayProjection and Geoserver, you'll find plenty of examples...
Best regards,
Zoran Jankovic
ZIS-Izrada softvera i savjetovanje / ZIS - Software Development and
Consulting
http://www.zisis.hr
M: 00 385 98 682 902
T:  00 385 44 683 374
A. Senoe 4
44320 Kutina
Croatia
On Wed, Jun 16, 2010 at 6:00 PM, Jefferson Heard <
jefferson.r.heard at gmail.com> wrote:
> Right, but GeoServer can; those servers can reproject my tiles for me, but
> I can't seem to figure out how to adjust the WMS request that OpenLayers is
> making.
> On Jun 16, 2010, at 11:52 AM, <christopher.schmidt at nokia.com> <
> christopher.schmidt at nokia.com> wrote:
> > On Jun 16, 2010, at 11:47 AM, ext Jefferson Heard wrote:
> >> I'm trying to layer a WMS layer onto an OpenStreetMaps map.  I'm getting
> WMS layers from WMSGetCapabilities records coming from GeoExt.  My base
> layer is, of course, spherical mercator (OSM), but my WMS layers are
> EPSG:4326 - namely the NOAA Weather Radar Mosaic and IR base reflectivity
> images.  Does anyone know how to do this?  Currently, I'm doing this:
> >> var grid = Ext.getCmp('avail_overlays_grid');
> >> var record = grid.getSelectionModel().getSelected();
> >> if(record) {
> >>      var copy = record.copy();
> >>      copy.data["layer"] =  record.get("layer");
> >>      copy.get("layer").mergeNewParams({
> >>              format: "image/png",
> >>              transparent: true,
> >>               reproject: true
> >>      copy.get("layer").shared=false;
> >>       copy.get("layer").displayInLayerSwitcher=true;
> >>       panel.layers.add(copy);
> > All raster layers must be in the same projection. OpenLayers
> > can't reproject images.
> > Regards,
> > Christopher Schmidt
> > Nokia
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100616/9b3e7a3a/attachment.html
