[OpenLayers-Users] How to SetUp Open Layers for an XML/WMS Service
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Tue Jun 29 03:11:11 EDT 2010
the closest code is probably the ArcIMS layer, since this also uses XML
for the communication.
It probably means writing a Format, just like Format.ArcXML for the ArcIMS
layer, and writing a layer type.
Unless you just want to use WMS, which comes out of the box.
Best regards,
Bart
>   Hello Everyone,
> I am new to Java Script and thus Open Layers. I have an application server
> that provides a map service and many other services like select, zoom in
> zoom out.I wanted to map them on to Open layers and finally embed open
> layers on to a website. The map service is an XML based and it generates
> an
> XML response.I also have WMS services that respond in WMS format.
> Could someone share me the procedure to make the above process to work
> please. I know a bit of Java Script. Like how it works and how to code in
> it
> and the function,Object structure of it. But, I never worked on it.
> Regards,
> Kalyan
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
