[OpenLayers-Users] How to SetUp Open Layers for an XML/WMS Service
Kalyan Kamepalli kalyan.kamepalli at gmail.com
Tue Jun 29 23:41:12 EDT 2010
Hi group,
I do have a WMS service with my product, I am actually trying to use
Smallworld Geospatial Server with WMS service. I just found one example
using WMS service and trying to edit it to work with my service call. I
changed the script section as follows
<script type="text/javascript">
            var map = new OpenLayers.Map('map',{maxResolution: 0.703125} );
            var wmscURL = [
http://localhost:8080/gss/ogc?request=GetMap&service=WMS&version=1.3.0&width=600&height=600&format=image/jpeg&bbox=545130525,258147752,546437807,259455034&crs=sw:uk_british_national_grid_mm
http://wmsc1.terrapages.net/getmap?",
http://wmsc2.terrapages.net/getmap?",
http://wmsc3.terrapages.net/getmap?",
http://wmsc4.terrapages.net/getmap?"
            //var terrapagesStreetLayer = new OpenLayers.Layer.WMS(
'TerraPages Street',wmscURL, {layers: 'UnprojectedStreet', format:
'image/jpeg' }, {buffer: 1, isBaseLayer: true} );
            //map.addLayer(terrapagesStreetLayer);
            map.zoomToMaxExtent();
</script>
As I don’t want to display any other map, I commented those 4 map requests
and included my request. But, It doesn’t give me any map. What could be
reason for that ??
If I use the same URL directly from a browser, I could see a map.  Is there
something I am missing ? or is it not the way to call a map service ??
Thanks,
Kalyan
On Tue, Jun 29, 2010 at 5:05 PM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> have a look thru the examples
> http://www.openlayers.org/dev/examples/
> that should be a good starting point, use view source to see how things are
> done
> z
> On 29 June 2010 13:44, Kalyan Kamepalli <kalyan.kamepalli at gmail.com>
> wrote:
> > Hello Everyone,
> > I am new to Java Script and thus Open Layers. I have an application
> server
> > that provides a map service and many other services like select, zoom in
> > zoom out.I wanted to map them on to Open layers and finally embed open
> > layers on to a website. The map service is an XML based and it generates
> an
> > XML response.I also have WMS services that respond in WMS format.
> > Could someone share me the procedure to make the above process to work
> > please. I know a bit of Java Script. Like how it works and how to code in
> it
> > and the function,Object structure of it. But, I never worked on it.
> > Regards,
> > Kalyan
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100630/e6af2325/attachment.html
