[OpenLayers-Users] text markers
Germán Carrillo carrillo.german at gmail.com
Tue Mar 2 10:39:10 EST 2010
Hi Karina,
I've just seen in another message this link [1], it can help you. As Eric
said you, it uses the OpenLayers.Layer.Vector but it reads your text file as
well.
Regards.
Germán
[1] http://openlayers.org/dev/examples/dynamic-text-layer.html
2010/3/2 Eric Lemoine <eric.lemoine at camptocamp.com>
> On Monday, March 1, 2010, Karina Guardado <kguardado at gmail.com> wrote:
> > Hi,
> > Is there a way to change the box of a text layer maker to one that has a
> close option like other popups. I mean when I click on one marker a box is
> opened but there is not option to close it just click again in the marker
> icon.
> Hi.
> What you want isn't supported.
> Using a Layer.Vector and a Control.SelectFeature is recommended.
> Although it would lead to more code on your side it would give you
> more flexibility.
> If you really want to use Layer.Text you can probably monkeypatch the
> prototype of feature so popups are created with a closebox by default:
> var _createPopup = OpenLayers.Feature.prototype.createPopup;
> OpenLayers.Feature.prototype.createPopup = function() {
>    _createPopup.call(this, true);
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
 |\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100302/d2678d14/attachment.html
