[OpenLayers-Users] Trying to get sundials example to work locally
MikeF mdfirman at gmail.com
Thu Mar 4 12:03:13 EST 2010
Hello all,
I have been studying the 'sundials' example of loading markers from a kml
file:
http://www.openlayers.org/dev/examples/sundials.html
I have been trying to get this to work locally on my computer. To do this, I
copied the source code of the file into a blank html file on my computer,
and downloaded all the files referred to (e.g. css, js, kml) into the same
folder. I then changed all the references in the sundials.html file to point
to the local files.
For example,
                    url: "kml/sundials.kml",
became:
                    url: "sundials.kml",
and
    <script src="../OpenLayers.js"></script>
became
    <script src="OpenLayers.js"></script>
, with the files referenced in the same folder as sundials.html.
However, having done this the page does not open correctly. The map is
displayed, and I can pan and zoom on it. However, none of the markers are
displayed. I have used FireBug but discovered no errors in the code. I have
tried both leaving the kml file as is, and changing the global icon links
(to http://maps.google.com/mapfiles/kml/shapes/sunny.png) to point to a
local file.
Has anyone else had any luck with this? Managing to do this would help me to
add my own kml markers.
Many thanks for any help,
Mike
View this message in context: http://n2.nabble.com/Trying-to-get-sundials-example-to-work-locally-tp4675616p4675616.html
