[OpenLayers-Users] OpenLayers.Layer.MapServer.Untiled
bartvde at osgis.nl bartvde at osgis.nl
Fri Mar 5 09:20:41 EST 2010
add the following to your MAP file:
MAP
  MAXSIZE 3000
Best regards,
Bart
> Hi all;
> This is my Layer definition;
> var mapserv = new
> OpenLayers.Layer.MapServer.Untiled("MapServer","http://192.168.2.15/cgi-bin/world_900913?",
> {layers:'World_Sea',transparent:true,
> format:"image/png",srs:"epsg:900913"},{buffer: 0, gutter: 0,isBaseLayer:
> false, opacity:0.5});
> This is the message returned;
> msUpdateMapFromURL(): Web application error. Image size out of range.
> The url of this error is;
> http://192.168.2.15/cgi-bin/world?layers=World_Sea&transparent=true&format=image%2Fpng&srs=epsg%3A900913&mode=map&map_imagetype=png&mapext=1302981.4204699+3362934.2490722+6586308.8145949+6088984.4253464&imgext=1302981.4204699+3362934.2490722+6586308.8145949+6088984.4253464&map_size=2160+1114&imgx=1080&imgy=557&imgxy=2160+1114
> But if I delete after map_size definition, it works!!! ;
> What did I miss?
> http://n2.nabble.com/OpenLayers-Layer-MapServer-Untiled-tp4681036p4681036.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
