[OpenLayers-Users] Drawing "Area of Interest" rectangle
Armin Burger armin.burger at gmx.net
Sun Mar 7 12:48:27 EST 2010
Hi all
I'm looking for a possibility for a tool that allows a user to draw a
rectangle on the map that is used as area of interest for a spatial
query. The rectangle should persist on the map so the user still sees
for which region he was searching.
I tried a Control.DrawFeature with a Handler.Box. This draws a rectangle
but it disappears after drawing.
If I use the Handler RegularPolygon then I have not found how to limit
the drawing to a straight rectangle (I got just a square that a user can
still turn). In addition, this drawing is added to a layer and this
layer is visible in the LayerSwitcher. Is there a possibility to avoid
the drawing layer being added to the Switcher?
Thanks in advance for any hints or pointing me to an example.
Armin
