[OpenLayers-Users] Make vector layer from JSON
Arnd Wippermann arnd.wippermann at web.de
Sun Mar 7 17:43:56 EST 2010
Hello Robert,
I don't know ArcGis Server, but I would look, if you can get your data in
gml or kml. Otherwise you have to write your own parser.
Arnd
  _____
Von: Robert Sanson [mailto:SansonR at asurequality.com]
Gesendet: Sonntag, 7. März 2010 21:09
An: 'Hugo'; Arnd Wippermann
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Make vector layer from JSON
I am wrestling with a similar problem. I am trying to read in data coming
from an ArcGIS Server in JSON format. Unfortunately, ArcGIS Server doesn't
serve GeoJSON. Here is a sample of what the data looks like:
  "results" : [
      "layerId" : 0,
      "layerName" : "Main_Gates",
      "displayFieldName" : "road_name",
      "foundFieldName" : "farm_id",
      "value" : "AS00136",
      "attributes" : {
        "point_location_id" : "232495",
        "farm_id" : "AS00136",
        "rapid_no" : "104",
        "road_name" : "Winslow Willowby Rd",
        "locality" : "Null",
        "x_nztm" : "1492934.61",
        "y_nztm" : "5131545.29",
        "Shape" : "Point"
      "geometryType" : "esriGeometryPoint",
      "geometry" :
        "x" : 1492934.61,
        "y" : 5131545.29,
        "spatialReference" : {
          "wkid" : 2193
Any ideas how to get OL to read this into a Vector layer?
Thanks,
Robert
>>> "Arnd Wippermann" <arnd.wippermann at web.de> 7/03/2010 10:43 a.m. >>>
i would think, that you have to use geojson instead of json, to get the
geometry for the features.
Arnd
  _____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Hugo
Gesendet: Samstag, 6. März 2010 19:14
An: openlayers
Betreff: [OpenLayers-Users] Make vector layer from JSON
Hello all,
I'm trying to create a vector layer based on a php query (which includes
the_geom) encoded in JSON. Until the moment i haven't been able to achieve
this.
Following, is the relevant part of the code:
var connect = new Ext.data.Connection();
connect.request({
    url: 'mfbase/geoquery.php',
    params: {
        species: species,
        datai: datai,
        dataf: dataf
    success: function(response){
        var resp = response.responseText;
        var json = new OpenLayers.Format.JSON();
        var data = json.read(resp);
        //console.log(data[0].the_geom);
        var querylayer1 = new OpenLayers.Layer.Vector(
            'Query1',
                isBaseLayer: false,
                projection: wgs,
                geometryName: 'the_geom',
        querylayer1.addFeatures(data);
        map.addLayer(querylayer1);
Any suggestions are more than welcomed :)
Thanks to you all!
Cheers,
Hugo Martins
FMV-UTL
CIISA-Epidemiologia e Saúde Pública Veterinária
Av. da Universidade Técnica
1300-477 Lisboa
N 38°42'49.54", W 9°11'43.42"
Click here <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==>  to
report this email as spam.
The contents of this email are confidential to AsureQuality. If you have
received this communication in error please notify the sender immediately
and delete the message and any attachments. The opinions expressed in this
email are not necessarily those of AsureQuality. This message has been
scanned for known viruses before delivery. AsureQuality supports the
Unsolicited Electronic Messages Act 2007. If you do not wish to receive
similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc.
<http://www.surfcontrol.com/> www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100307/642fd311/attachment.html
