[OpenLayers-Users] wfs not displaying
Sarah Schuessler sarah_flip at yahoo.de
Mon Mar 8 11:32:06 EST 2010
thanks for your suggestion!
Name of the layer is correct. I use featureType: "mylayer" (without prefix) and/or typename: "gn:mylayer" but neither worked.
Firebug gave me:
 gml:boundedby ><gml:null>unknown</gml:null>
I think because of different EPSG/coordinates. But don´t know how to manage best way.
best regards
Sarah
Hello,
What is the name of your layer in the Server? You don't seem to be passing that to the layer constructor. Do 2 things:
. confirm in the server the layer's name and that there's nothing wrong with it (accessing the demos at Geoserver);
. try a simpler layer setup like the following in a map with the same SRS:
var wfs2 = new OpenLayers.Layer.WFS(
                "myLayer",
                "http://myserver:81/geoserver/wfs",
                 typename: 'myLayersNameInTheServer',
If it shows as expected you can try to build it up from there.
Good luck,
Luís
On Mon, Mar 8, 2010 at 3:32 PM, Sarah Schuessler <sarah_flip at yahoo.de> wrote:
Hi list,
>I want to display a wfs layer but I get only a firebug response.
>My code:
>var wfs2 = new OpenLayers.Layer.Vector("WFS_",
>                {strategies: [new OpenLayers.Strategy.BBOX()],
>>                projection: new OpenLayers.Projection("EPSG:4326"),
>                protocol: new OpenLayers.Protocol.WFS({url: "http://myserver:81/geoserver/wfs",
>                    featureNS: "http://geonetwork-opensource.org",
>                    featureType: "mylayer",
>                    geometryName: "SHAPE",
>>                    srsName: "EPSG:4326",
>                    version: "1.0.0"})
>This is my respone:
>unknown5413933.11245331994.98768227296000555128200312150128202450mylayer
>2450
>3543559.9964835386316.2988641998-12-15T00:00:00.8192005-11-21T00:00:00.819
>2005-11-21T00:00:00.81963541658.27,5388303.67 3541634.73,5388307.71
>3541619.75,5388285.51 3541602.55,5388279.83 3541596.081,5388247.895
>3541594.57,5388243.972 3541590.42,5388232.1 3541589.45,5388229.34
>3541586.61,5388202.45 3541577.424,5388201.4 3541576.61,5388191.43
>3541572.56,5388165.36 3541569.52,5388146.47 3541488.02,5388172.96
>3541484,5388174.3 ...
>Post:
>http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd
>http://geonetwork-opensource.org http://myserver:81/geoserver/wfs/DescribeFeatureType?version=1.0.0&typename=gn:Erholungswald" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
>SHAPE
>9.2809876852504,48.409352045852 9.7190123147496,48.590647954148
>In fact that I have problems with OpenLayers.Control.GetFeature (to select features) I found out that I need to use other coordinates (Gauß
> Krüger) and only version 1.0.0 (version 1.1.0 gave me exception:
>ows:Exception
>exceptionCode="NoApplicableCode"><ows:ExceptionText>java.lang.RuntimeException:
>Encode
>      failed for numberOfFeatures. Cause: Value
>      &apos;-1&apos; must be
>non-negative (0 or
>      above). Encode failed for
>Value &apos;-1&apos; must be non-negative (0
>      or above). Value &apos;-1&apos;
>must be      non-negative (0 or above).. )
>If I use:
>var wfs2 = new OpenLayers.Layer.WFS("WFS_", "http://myserver:81/geoserver/wfs", {typename: "gn:mylayer", maxfeatures: 15},{featureClass: OpenLayers.Feature.WFS});
>>there is a request string with false bbox, so I need to reproject. I tried it with srsName and projection but nothing worked. I read something about format instead of featureClass but don´t know how to.
>I work with win server 2003. I put code at root of geoserver.
>>Where are my mistake(s)? Any hints are welcome!
>Thanks!
>best regards
>Sarah
>__________________________________________________
>Do You Yahoo!?
>Sie sind Spam leid? Yahoo! Mail verfügt über einen herausragenden Schutz gegen Massenmails.
>http://mail.yahoo.com
>>Users mailing list
>Users at openlayers.org
>http://openlayers.org/mailman/listinfo/users
Do You Yahoo!?
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100308/4a5d614b/attachment.html
