[OpenLayers-Users] Questions on using Protocol.HTTP and custom XML to load/edit features
Stephen Woodbridge woodbri at swoodbridge.com
Mon Mar 8 14:58:42 EST 2010
OK, to partially answer some of my own questions ... inline below.
Stephen Woodbridge wrote:
> Hi all,
> I am trying to implement a vector layer that will allow editing point
> data. The data is accessed via a PHP script that serves some arbitrary
> XML. The layer looks like this so far:
>              vector = new OpenLayers.Layer.Vector("POI", {
>                  maxResolution: 360.0/16777216/2, // zoom 15
>                  styleMap: styleMap,
>                  protocol: new OpenLayers.Protocol.HTTP({
>                      url: "poi-server.php",
>                      params: {
>                          m: 'r',
>                          srs: 'EPSG:4326'
>                      format: new OpenLayers.Format.XML()
>                  strategies: [
>                      new OpenLayers.Strategy.BBOX({ratio: 1}),
>                      new OpenLayers.Strategy.Save({
>                          auto: true//,
>                          //save: function() { alert("Save called."); }
> This seems like it almost works. But has the following problems, so
> maybe I'm just taking the wrong approach all together. Here is a live
> example:
> http://imaptools.com:8080/tilecache/test.html?zoom=17&lat=33.89595&lon=35.49935&layers=BT
> Issue:
> 1) the feature request does not seem to load on page load, but fires if
> you pan the map slightly
> 2) when the features load, I get an error on line 128 of
> OpenLayers/Format/XML.js because test.indexOf() is not a method. This is
> because text is type Document not string?
This appears to be because I need to write my own class like
OpenLayers.Format.MyXML that parses the XML document the PHP returns and
  returns an array of features. Working on writing this.
> 3) I assume the the XML parser will parse the response into an
> appropriate tree object, then I need to add some code that reads the
> tree and constructs feature objects that I then add to the layer. So is
> the problem above because the text object passed to read IS my tree and
> I need to pass a my own read() function to some code to do that? Where
> do I do that?
See 2) above.
> 4) If I add a point using the toolbar add point button, I get
> Security error"  code: "1000
> http://imaptools.com:8080/ol28/lib/OpenLayers/Format/XML.js
> Line 198
> data = serializer.serializeToString(node);
> What is this error and why am I getting it? I assumed that a default
> serializer exists, I probably need to add my own it write the expected
> XML the the PHP needs. Where would I add this and what are the exected
> inputs and outputs?
I'm hoping this is probably related to the above. will report back after
I get my XML parser working.
> 5) I eventually need to issue the Ajax requests by sending XML documents
> to the server instead of issuing GET requests. So to do this I assume I
> need to a) write code to serialize some params into a document, then b)
> get HTTP protocol to send the document. How do I do this? The PHP code
> is only temporary for testing and developing in my environment.
> I learned a lot today, just by reading lots of OL code but I still have
> a ways to go.
> I would appreciate and help and guidance.
Any thoughts on 1) or 5)? Just a pointer would be helpful :)
Perseverance pays off,
   -Steve
> Thanks,
>    -Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
