[OpenLayers-Users] zIndex and Base Layer
Maria Neywell maria.neywell at gmail.com
Tue Mar 9 03:08:57 EST 2010
thanks Bart,
My baselayer is a kamap layer.
I used this option and it doesn't work anymore.
2010/3/8 <bartvde at osgis.nl>
> What type is your base layer? WMS?
> If  so, you can use allOverlays: true on your MAP object.
> Best regards,
> Bart
> > Hi,
> > Here is my code,
> > layer_map is my base layer. I put it in order to display my map. As I
> > noticed layer_wms1 and layer_wms2 are not mine. It uses wms server from
> > other companies.
> > map.addLayer(layer_wms1);
> > map.addLayer(layer_wms2);
> > map.addLayer(layer_map);
> > In this configuration my layer_map doesn't display up to the other
> layers.
> > Do you understand ?
> > Maria
> > 2010/3/5 Christopher Schmidt <crschmidt at metacarta.com>
> >> On Fri, Mar 05, 2010 at 09:10:34AM +0100, Maria Neywell wrote:
> >> > I’m using some wms layers which don’t belong to me (are not mine).
> >> Only
> >> the
> >> > base layer is mine and I need to put it up to the others.
> >> Perhaps providing your existing code/HTML page would help clarify the
> >> current situation and what you plan to do.
> >> -- Chris
> >> > Maria
> >> > 2010/3/3 Christopher Schmidt <crschmidt at metacarta.com>
> >> > > On Wed, Mar 03, 2010 at 02:54:58PM +0100, Maria Neywell wrote:
> >> > > > Hi list,
> >> > > >                 The OpenLayer’s doc explains that “Base Layers
> >> always
> >> > > > display below overlay layers”. Is it a fatality or is it possible
> >> to
> >> have
> >> > > > the Base Layer always on top of the others layers ? I need to have
> >> my
> >> > > Base
> >> > > > Layer in front of the my others layers.  Is there any hack ?
> >> > > Why is it a base layer if you want it over the top of other layers?
> >> > > -- Chris
> >> > > > Thanks in advance,
> >> > > > Cheers,
> >> > > > Maria
> >> > > > _______________________________________________
> >> > > > Users mailing list
> >> > > > Users at openlayers.org
> >> > > > http://openlayers.org/mailman/listinfo/users
> >> > > Christopher Schmidt
> >> > > MetaCarta
> >> Christopher Schmidt
> >> MetaCarta
> > Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100309/653b02be/attachment.html
