[OpenLayers-Users] righ-click event stops left-click
dalsinao dalsinao at yahoo.es
Tue Mar 9 12:42:07 EST 2010
Hello all,
I want to capture in the same control both left and right click events.
Using examples, I've come to the control I add below. It seems to work fine:
Left click events are caught in my "onLeftClick" function and right click
events in "onRightClick" (see code below). However, after servicing for the
first time a right-click event, then left click event stops to work, even
though the right-click doesn't.
Any idea on which is the problem? Or any better alternative to catch right
and left click events?
I use the old and crappy IE6 (not my choice, but I have to support it
anyhow).
Thanks in advance for any help!
David
Here is the code...
OpenLayers.Control.CAXRightClick = OpenLayers.Class(OpenLayers.Control, {
    handleRightClicks: true,
    handleLeftClicks: true,
    defaultHandlerOptions: {
        'single': true,
        'double': true,
        'pixelTolerance': 0,
        'stopSingle': false,
        'stopDouble': false
    initialize: function(options) {
        this.handlerOptions = OpenLayers.Util.extend(
            {}, this.defaultHandlerOptions
        OpenLayers.Control.prototype.initialize.apply(
            this, arguments
        this.handlers = {};
        if (this.handleRightClicks){
            this.handlers.rightclick = new OpenLayers.Handler.Click(this,
{'rightclick': this.onRightClick}, this.handlerOptions);
        if (this.handleLeftClicks){
            this.handlers.leftclick = new OpenLayers.Handler.Click(this,
{'click': this.onLeftClick}, this.handlerOptions);
	onLeftClick: function(evt){
	    alert("left clicked on map");
	onRightClick: function(evt){
	    alert("right clicked on map");
    activate: function () {
        if (!this.active) {
            for(var i in this.handlers) {
                this.handlers[i].activate();
        return OpenLayers.Control.prototype.activate.apply(
            this, arguments
    deactivate: function () {
        if (this.active) {
                this.handlers[i].deactivate();
        return OpenLayers.Control.prototype.deactivate.apply(
            this, arguments
    setMap: function(map) {
        OpenLayers.Control.prototype.setMap.apply(this, arguments);
        if (this.handleRightClicks && (typeof(this.handlers.rightclick) !=
"undefined")){
            this.handlers.rightclick.setMap(map);
        if (this.handleLeftClicks && (typeof(this.handlers.leftclick) !=
"undefined")){
            this.handlers.leftclick.setMap(map);
        this.disableContextMentu();
View this message in context: http://n2.nabble.com/righ-click-event-stops-left-click-tp4703752p4703752.html
