[OpenLayers-Users] slimming OL
Wendell Turner wendell at enflight.com
Tue Mar 9 17:27:32 EST 2010
> > > > > You could use OpenLayerer to do so :
> > > > > http://openlayerer.appspot.com/
> > >   http://docs.openlayers.org/library/deploying.html#custom-build-profiles
> > Cool.  I tried that, and was able to reduce my OpenLayers.js
> > to 371K (or 52%, I'm using a lot of Controls and Handlers).
> > Everything works, but this:  when modifying a LineString,
> I am not aware of any reason this would be tied to a custom build
> versus a non-custom build. It sounds like a different default of the
> 'clickout' parameter; are you using the same version in both cases?
Duh!  I forgot that I had to add the clickout patch from
ticket #2204.  The custom build procedure, once figured out,
works fine.
Wendell
