[OpenLayers-Users] Disable select control only for some features in a layer
Olivier THIERRY olivier.thierry at gmail.com
Wed Mar 10 03:30:46 EST 2010
2010/3/9 Eric Lemoine <eric.lemoine at camptocamp.com>:
> On Tue, Mar 9, 2010 at 10:54 AM, Olivier THIERRY
> <olivier.thierry at gmail.com> wrote:
>> Hi,
>> I have a Vector layer with two kinds of vectors : lines and points.
>> I enabled select control for lines, both from user click on the
>> feature and user click on a button outside the map.
>> For the points I need to enable select control on a user click on a
>> button outside the map, but I want to disable select control if the
>> user clicks on the feature on the map.
>> Since the lines and the points are in the same layer and the select
>> control is enabled for the layer, is there a way to tell OpenLayers to
>> disable the select control for some features on the layers ?
> Hi.
> Setting geometryTypes to ["OpenLayers.Geometry.LineString"] in the
> select feature options should do the trick.
> Cheers,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
It works perfect !
Thanks a lot !
Merci beaucoup ;)
Olivier
