[OpenLayers-Users] Corrupted selection in IE8
bartvde at osgis.nl bartvde at osgis.nl
Wed Mar 10 04:32:42 EST 2010
Can you check if OpenLayers trunk still has this issue?
Bart
> Sorry for bumping this message, but I could really use a hint.
> More in detail:
> It happens when I select a feature. I highlight the selected feature and
> it looks okay. But when I change the zoomlevel, it gets distorted like
> seen in the previous links. Again, the problem is only in IE - not in FF.
> I hope one of you can tell me where to look for the solution.
> Regards, Casper
> -----Oprindelig meddelelse-----
> Fra: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] På
> vegne af Casper Børgesen
> Sendt: 12. februar 2010 14:48
> Til: users at openlayers.org
> Emne: [OpenLayers-Users] Corrupted selection in IE8
> Hi!
> I have encountered this strange behavior in IE8.
> See:
> Corrupted: http://imgur.com/2HyEP&BTJ13l
> Normal: http://imgur.com/2HyEPl&BTJ13
> It happened when I selected an object (it's a lake) and was trying to
> visualize it using OL 2.8. Usually this works but suddenly it didn't.
> After refreshing the page, everything is back to normal and I can select
> again. I haven't encountered this in FF and very rarely in IE8.
> But I would like to know what causes this problem, so that I might avoid
> it in the future.
> Does anyone know why this is happening?
> Regards Casper
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> Users mailing list
