[OpenLayers-Users] show two layers with different projections
Robert Sanson SansonR at asurequality.com
Thu Mar 11 16:10:44 EST 2010
When a server such as Geoserver or Mapserver can support more than one projection, OpenLayers needs to send a request to return each layer in the same projection used by your map, otherwise the server may not know to send it in the correct projection, in which case the data will not line up in your browser.
>>> GeoGEOrge <awmlamp at yahoo.com> 12/03/2010 10:04 a.m. >>>
It seems that when I fail to define the polygon layer as EPSG:2249, it fails
to display.
View this message in context: http://n2.nabble.com/show-two-layers-with-different-projections-tp4717734p4718648.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100312/4a98c382/attachment.html
