[OpenLayers-Users] How to programmatically open/close Popup?
Stephen Woodbridge woodbri at swoodbridge.com
Thu Mar 11 23:33:55 EST 2010
Hi all,
I have an OpenLayers.Popup.FramedCloud popup that contains a form for
entering/editing a features attributes. The form has a save button with
an onClick function attached that needs to save the data to the server
then close the popup. Currently the button only issue an alert.
How can I programmatically trigger the close from my onclick handler?
You can see example here:
http://imaptools.com:8080/tilecache/test.html?zoom=17&lat=33.89595&lon=35.49935&layers=BT
1) load page, pan slightly to work around feature load bug
2) click left most tool in tool bar
3) click on green POI (you should get popup)
I have only worked on this in FF, others might not work yet.
I have looked over the event code and the popup code, but I'm not seeing
a way to do this.
Thanks,
   -Steve
