[OpenLayers-Users] WMS Server Openlayers EPSG:31467
Arnd Wippermann arnd.wippermann at web.de
Fri Mar 12 14:16:19 EST 2010
you use for the map the projection "EPSG:4326", but your mapfile is only
configured for "EPSG:31467". You should get back a broken image instead of a
blank image.
Modify in the WEB METADATA  WMS_SRS "EPSG:31467 EPSG:4326" (and more
projections if you like), then you should get a response.
Arnd
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100312/ab5be4df/attachment.html
