[OpenLayers-Users] OSM2pgsql, latlong, OpenStreetMap data,
	uDig = weird projection
    Mulone
    mulone at rome.com
    Mon Mar 15 08:46:14 EDT 2010
Hi guys,
I have an issue trying to import OSM data on PostGIS.
I download an xml file from the CloudMade site.
I use this script to import the file into postgis (on Windows, latlong
projection):
./osm2pgsql -U userId -W -H myhost -d maps -p myprefix -S default.style -c
-l data.osm.bz2
This works, but when I visualise the spatial data on uDIG (default
projection: WGS84) proportions are wrong. The vertical axis is much shorter
than it is on regular online maps (e.g. openstreetmap.org, google maps,
etc), like here: http://img7.imageshack.us/img7/8279/imagelw.png
So I read somewhere that the OSM data is stored in mercator, and I tried to
run the same script with -m option:
-m data.osm.bz2
The command works but then I can't visualise any data in uDig.
How can I load OSM data with the right SRS and then project it properly?
Cheers,
Mulone
Mulone
PhD student
View this message in context: http://n2.nabble.com/OSM2pgsql-latlong-OpenStreetMap-data-uDig-weird-projection-tp4736663p4736663.html
