[OpenLayers-Users] Write a KML file in proper projection.
bartvde at osgis.nl bartvde at osgis.nl
Mon Mar 15 08:36:26 EDT 2010
Right, it's as simple as that.
Although for proj4js I use a custom build with the projections I use in my
application compiled into the javascript build.
Proj4js by default will get definitions from spatialreference.org.
Best regards,
Bart
> Are there any examples of using Proj4js with OpenLayers anywhere?
> Or is it as simple as just including the proj4js javascript file?
> - Kristian Frost
> http://n2.nabble.com/Write-a-KML-file-in-proper-projection-tp4736343p4736599.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
