[OpenLayers-Users] zoomToScale Issue
Andrew Haigh haighaj+ollist at googlemail.com
Wed Mar 17 11:33:11 EDT 2010
Thanks for your help, that is correct I was using a WMS without any fixed
resolution / cached layers.
Adding the code you suggested resolved this issue.
Many thanks
Andrew
On 17 March 2010 13:01, Mapmaker <bmcbride at chacompanies.com> wrote:
> If you are using WMS without fixed-resolution or cached layers, you might
> want to try adding the following:
> map.fractionalZoom = true;
> http://n2.nabble.com/zoomToScale-Issue-tp4749135p4750026.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100317/9a8ad1c1/attachment.html
