[OpenLayers-Users] Ajax problem - Cross Domain?
David Alda Fernandez de Lezea dalda at ikt.es
Thu Mar 18 04:03:05 EDT 2010
Hello,
Thanks for your response. Does this work with IP addresses?
I mean, that I still don't have no www.example.com address for instance.
What do you think about writing a server side proxy (php, asp, whatever)?
P.S. I'm quite newbie in this stuff.
-----Mensaje original-----
De: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] En nombre de Tim Schaub
Enviado el: miércoles, 17 de marzo de 2010 22:00
Para: openlayers users
Asunto: Re: [OpenLayers-Users] Ajax problem - Cross Domain?
David Alda Fernandez de Lezea wrote:
> Hello,
> We're developing a library based on OpenLayers (a simple GIS viewer with some special configuration) that will be included in some web applications. These applications will include our library with a script tag in their html code, and the applications are in different servers and domains. Testing a bit all these stuff, we get an error:
> NETWORK_ERR: XMLHttpRequest Exception 101
> This error appears in a function that loads a XML config file synchronously. This XML file is hosted in a server and the code from where is invoked is in another.
> Is this a cross-domain error??
> At first sight I thought it was a cross-domain error and found some suggestions of how to solve it. One of them was very interesting: using apache mod_rewrite module. I decided to give it a try but I think I'm not using it properly. Here is what I put in httpd.conf file:
>  <Directory /ms4w/Apache/htdocs>
>    RewriteEngine on
>    RewriteRule ^vcw/data/IKT_OGC_Services.xml$
> http://192.168.1.38/vcw/data/IKT_OGC_Services.xml
>  </Directory>
With mod_proxy, assuming you want to proxy http://example.com/remote/path
<VirtualHost *>
     ProxyRequests Off
     # turn the next line off if you are proxying to a NameVirtualHost
     ProxyPreserveHost On
     <Proxy *>
         Order deny,allow
         Allow from all
     </Proxy>
     ProxyPass /local/path http://example.com/remote/path
     ProxyPassReverse /local/path http://example.com/remote/path
</VirtualHost>
> Does anybody know how to configure it?
> Some info:
> GIS viewer is in 192.168.1.65
> Apps are in 192.168.1.38
> And I think that they are in different domais.
> Un saludo,
> David Alda Fernández de Lezea
> Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y
> Biodiversidad
> IKT
> Granja Modelo s/n · 01192 · Arkaute (Araba)
> Tlfnos.: 945-00-32-95                         Fax: 945-00.32.90
> email: dalda at ikt.es                                web: www.ikt.es
> ············ _______________________________________________
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
Users mailing list
