[OpenLayers-Users] Doubt with SOSCapabilities
Maribel Bernal maribel.bernal at iviron.com
Thu Mar 18 09:16:31 EDT 2010
Thanks Bart for your help.
I will ask on the 52N list, I keep you informed if I find a solution.
Regards,
Maribel.
bartvde at osgis.nl escribió:
> Ok, I get what you mean now.
> However, I can not deduct from the GetCapabilities response that DISTANCE
> is only applicable for that feature of interest.
> What interface (request) does a SOS have to get that information
> programmatically? If you do not know, maybe you can ask on the 52N list.
> But currently this is not possible using the OpenLayers SOS client,
> however if you find out exactly how to implement this, and open up a bug
> in the OpenLayers Trac, I am willing to have a look at implementing it.
> TIA.
> Best regards,
> Bart
>> Yes, my SOS structure is a little bit different. You can see my SOS's
>> GetCapabilites response here: http://pastebin.com/vwr3nx37
>> An example of my question is at this tag (line #750):
>> <sos:ObservationOffering gml:id="DISTANCE">
>> where the offering named "DISTANCE" has 10 procedures, of which only one
>> really belongs to feature 'foi_k2m_contenedor' (the other nine
>> procedures are from other features).
>> When I click over the point 'foi_k2m_contenedor' in the map, I see a
>> popup in which they appear all 10 procedures. I just want to see the
>> procedure that belongs to 'foi_k2m_contenedor' feature. It's possible?
>> Thanks for all.
>>> Hi,
>>> not sure I really get your question, can you elaborate a bit? Is this
>>> something you can read from the GetCapabilities, or the info needs to be
>>> retrieved through a request on the SOS? If so, which request, and do you
>>> have an example XML request?
>>> If I understand things correctly, in the example SOS used one feature of
>>> interest has exactly one procedure, and they have the same id.
>>> Is your SOS structure different, and if so, can you post your SOS's
>>> GetCapabilities response using something like pastebin? TIA.
>>> Best regards,
>>> Bart
>>>> Hi all,
>>>> Following the example (http://openlayers.org/dev/examples/sos.html),
>>>> I'm
>>>> using OpenLayers.js to connect by my local SOS which is based to
>>>> 52North
>>>> model, and it works correctly.
>>>> I have seen the result of the GetCapabilities request is an array of
>>>> "offerings", and within each offering there are two separate arrays:
>>>> the
>>>> "features of interest" and the "procedures" related with this offering.
>>>> In the map, I can see the points that represents the "features of
>>>> interest". When I click over a point, due to each feature can have one
>>>> or more "offerings" associated, in the popup I see all the procedures
>>>> related by all offerings of this FoI.
>>>> My question is:
>>>> There are any way to directly obtain only the "procedures" of a
>>>> "feature
>>>> of interest" regardless the offerings?
>>>> Thank you very much.
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>> Users mailing list
