[OpenLayers-Users] Get Feature Info in pop up working example
sunny74 sb.ray at hotmail.com
Mon Mar 22 01:28:10 EDT 2010
Hi Robert,
Thanks for your reply.
There are a few doubts about the code:
1) If you taken a single lonlat and then made a bounding box(BBOX) by doing
+- 10.
But what if I want to get the feature info of just one point.What will be
the url in that case?
2) The url is "var regc =
"http://ws-esrimt/arcgis/services/mapservice_asurequality_prod/MapServer/WMSServer?service=WMS&version=1.1.1&request=GetFeatureInfo&QUERY_LAYERS=2&INFO_FORMAT=text/plain&SRS=EPSG:2193&BBOX="
+ bbox1 + "," + bbox2 + "," + bbox3 + "," + bbox4 +
"&WIDTH=20&HEIGHT=20&X=10&Y=10";"
  It seems from the url that you r using ARCGIS with Mapserver. But if I am
using
only mapserver with openlayers then what is the url?
3) HOw do I make a layers queryable in the map file? What r the extra things
I need to specify?
Pls reply soon.
View this message in context: http://n2.nabble.com/Get-Feature-Info-in-pop-up-working-example-tp4773944p4776299.html
