[OpenLayers-Users] problem with map.setCenter(....
T at f!t grob_david at gmx.ch
Mon Mar 22 17:38:42 EDT 2010
Now it works. I had to make a global Variable as Mapmaker told. And then it's
importent that  the <div id="map> is BEFORE the Script where I initialise
the map. I don't understand why but it works...
  <body>
 <div id="map"></div>
<script type="text/javascript">
                var bounds = new OpenLayers.Bounds(
                143, -44,
                149, -39
                var options = {
                controls: [],
                maxExtent: bounds,
                maxResolution: 1.200597656250011,
                projection: "EPSG:4326",
                units: 'm',
                var map = new OpenLayers.Map('map',options);
View this message in context: http://n2.nabble.com/problem-with-map-setCenter-tp4779851p4780651.html
