[OpenLayers-Users] Get Feature Info in pop up working example
sunny74 sb.ray at hotmail.com
Tue Mar 23 06:15:52 EDT 2010
Hi Robert,
Thanks for your reply.
how do u create the following files:
HEADER   ../templates/synlait_query_header.html
  TEMPLATE ../templates/synlait_query_body.html
Pls send the html code for the above and also pls compare your format in
these two files with the actual data of the .shp file as you see in DB.
Thanks again.
View this message in context: http://n2.nabble.com/Get-Feature-Info-in-pop-up-working-example-tp4773944p4783231.html
