[OpenLayers-Users] Performance of different layers
Mapmaker bmcbride at chacompanies.com
Wed Mar 24 14:27:22 EDT 2010
Hi Hanno,
If you are storing your data in a PostGIS database, you can extract your
data in an openlayers friendly format (KML, GML, GeoJSON) using a SELECT
ST_AsKML query.  See  http://postgis.refractions.net/docs/ST_AsKML.html
You could also write a php script that queries the database and writes out
the KML file with the style pulled from a database variable.
Alternatively, you could use GeoServer or MapServer to serve your data and
apply SLD styles as needed.  See
http://openlayers.org/dev/examples/sld.html
Hope this helps and best of luck!
BRYAN
View this message in context: http://n2.nabble.com/Performance-of-different-layers-tp4792074p4792884.html
