[OpenLayers-Users] Large geodesic errors over long distances
realjax jax at schildmos.nl
Fri Mar 26 03:46:06 EDT 2010
When I try using the measure tool on my map (google projection) I get *huge*
distance differences when I test it over long distances (draw a line from
Japan to US crossing Africa for instance). With geodesic turned on it says
this is a couple of thousand kilometers, with geodesic turned off it gives
me a more accurate ( 70.000 kilometers).
You can see for yourself in the  measure example @
http://openlayers.org/dev/examples/
Any idea what's causing this? Is there a fix?
Thanks & regards
View this message in context: http://n2.nabble.com/Large-geodesic-errors-over-long-distances-tp4802534p4802534.html
