[OpenLayers-Users] vector layer shifts when i zoom or pan the base layer
sapmaster sapmaster at rediffmail.com
Sat Mar 27 02:12:29 EDT 2010
	 hi friends,
I am using the latest build of Openlayers and asp.net 3.5 I can add points and polygons etc in a vector layer but why does the vector layer shift when i zoom or pan the base layer? it shifts by a very small fraction, but it looks very bad for a mapping application. while the marker does not shift at all.
so is there is a problem with projection? or my code?
i use the following code
vectors = new OpenLayers.Layer.Vector("Vector Layer"); var gphy = new OpenLayers.Layer.Google( "Google Physical", { type: G_PHYSICAL_MAP }); var gmap = new OpenLayers.Layer.Google("Google Streets", { 'sphericalMercator': false }); var gsat = new OpenLayers.Layer.Google("Google Satellite", { type: G_SATELLITE_MAP, 'sphericalMercator': false }); var ghyb = new OpenLayers.Layer.Google("Google Hybrid", { type: G_HYBRID_MAP, 'sphericalMercator': false });
... and ...
wfs = new OpenLayers.Layer.Vector("Editable Features", { strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy], projection: new OpenLayers.Projection("EPSG:4326"), protocol: new OpenLayers.Protocol.WFS({ version: "1.1.0", //opacity: 0.3, srsName: "EPSG:4326", url: "http://demo.opengeo.org/geoserver/wfs", featureNS: "http://opengeo.org", featureType: "restricted", geometryName: "the_geom", schema: "http://demo.opengeo.org/geoserver/wfs/DescribeFeatureType?version=1.1.0&typename=og:restricted" }) }); please help.
Thanks
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100327/71c63225/attachment.html
