[OpenLayers-Users] How to print map area with openlayers
guillaumev guillaume at viguierjust.com
Mon May 3 17:58:41 EDT 2010
Just in case someone encounters the same problem (i. e. when moving the map,
it is printed in its initial position), I solved it by adding the position
of the viewport (map.layerContainerDiv.style.left and
map.layerContainerDiv.style.top), and then adding the left value of the
viewport to the $tile->x and the top value of the viewport to the $tile->y
in the calls to imagecopymerge_alpha.
Here is my full client code (I encapsulated the map object within an
object):
this.print = function(print_url, callback) {
		var size = this.map.getSize();
		var tiles = [];
		var nb_layers = this.map.layers.length;
		var layeri = 0;
		var nb_vector_layers = 0;
		var features = [];
		for (layeri = 0; layeri < nb_layers; layeri++) {
			// if the layer isn't visible at this range, or is turned off, skip it
			var layer = this.map.layers[layeri];
			if (!layer.getVisibility()) continue;
			if (!layer.calculateInRange()) continue;
			if (layer.grid) {
				// iterate through their grid's tiles, collecting each tile's extent and
pixel location at this moment
				var grid_length = layer.grid.length;
				var row_length = 0;
				var tilerow = 0;
				var tilei = 0;
				for (tilerow = 0; tilerow < grid_length; tilerow++) {
					row_length = layer.grid[tilerow].length;
					tilei = 0;
					for (tilei = 0; tilei < row_length; tilei++) {
						var tile     = layer.grid[tilerow][tilei];
						var url      = layer.getURL(tile.bounds);
						var position = tile.position;
						var opacity  = layer.opacity ? parseInt(100*layer.opacity) : 100;
						var bounds = tile.bounds;
						tiles[tiles.length] = {url:url, x:position.x, y:position.y,
opacity:opacity, bounds:{left:bounds.left, right: bounds.right, top:
bounds.top, bottom: bounds.bottom}};
			} else {
				// get the features of the layer
				var olFeatures = layer.features;
				var features_temp = [];
				var styles = {};
				var nb_features = layer.features.length;
				var featuresi = 0;
				var nextId = 1;
				for (var i = 0; i < nb_features; i++) {
					var feature = olFeatures[i];
					var style = feature.style || layer.style ||
layer.styleMap.createSymbolizer(feature, feature.renderIntent);
					if(feature.geometry) {
						if (feature.geometry.CLASS_NAME.search(/point$/i) >= 0) {
							var fpos = this.map.getLayerPxFromLonLat(new
OpenLayers.LonLat(feature.geometry.x, feature.geometry.y));
							if(fpos != null) {
								features_temp[featuresi] = {type: 'point', x: fpos.x, y:fpos.y,
style: style};
								featuresi++;
				features[nb_vector_layers] = features_temp;
				nb_vector_layers++;
		// hand off the list to our server-side script, which will do the heavy
lifting
		var tiles_json = JSON.stringify(tiles);
		var features_json = JSON.stringify(features);
		var viewport_left = parseInt(this.map.layerContainerDiv.style.left);
		var viewport_top = parseInt(this.map.layerContainerDiv.style.top);
		var viewport = {top: viewport_top, left: viewport_left};
		var viewport_json = JSON.stringify(viewport);
		var scale = Math.round(this.map.getScale());
		OpenLayers.Request.POST(
		  { url:print_url,
data:OpenLayers.Util.getParameterString({width:size.w,height:size.h,scale:scale,viewport:
viewport_json,tiles:tiles_json,features:features_json}),
			headers:{'Content-Type':'application/x-www-form-urlencoded'},
			callback: callback
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-print-map-area-with-openlayers-tp4901023p5000414.html
