[OpenLayers-Users] RootContainer styleMap problem- IE
Andreas Hocevar ahocevar at opengeo.org
Wed May 5 03:20:16 EDT 2010
On May 5, 2010, at 04:15 , mortac8 wrote:
> It turns out my problem occurs because I am setting a custom layer.id after I
> create an OpenLayers.Layer.
> I guess my next question is:  Is there any way to provide your own custom ID
> when creating a layer?  If you provide it via the options object, the div
> never gets created.
The only workaround would be to do something like
var layer = new OpenLayers.Layer(...);
document.getElementById(layer.id).id = myCustomId;
layer.id = myCustomId;
The above should work, but is untested.
Regards,
Andreas.
> Andreas Hocevar-2 wrote:
>> Hi,
>> posting an example that shows the issue would help. I suspect that your
>> StyleMap has incomplete symbolizers.
>> Regards,
>> Andreas.
>> On May 4, 2010, at 05:55 , mortac8 wrote:
>>> I forgot to add that my Point features with an externalGraphic retain
>>> their
>>> styling (no problems).  The loss of styling issue seems to only occur
>>> with
>>> Polygons, Polylines, etc.
>>> mortac8 wrote:
>>>> In IE 7/8 when I create a SelectFeature control and pass in an array of
>>>> layers, all of my features' styles  are lost (am using a custom
>>>> StyleMap).
>>>> If I modify Control/SelectFeature:initLayer to pass the styleMap to the
>>>> RootContainer constructor, the styles will take effect if I redraw after
>>>> activating the tool.  However IE makes such a redraw operation painfully
>>>> slow.
>>>> Is there any way in IE that I can activate the SelectFeature control
>>>> with
>>>> an array of layers and have my features keep their styling without an
>>>> expensive redraw of the layers?  As usual, this problem doesn't exist in
>>>> other browsers.
>>>> Ideas are greatly appreciated.  Thanks!
>>> View this message in context:
>>> http://osgeo-org.1803224.n2.nabble.com/RootContainer-styleMap-problem-IE-tp5001602p5001623.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Users mailing list
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/RootContainer-styleMap-problem-IE-tp5001602p5006913.html
> Users mailing list
Andreas Hocevar
