[OpenLayers-Users] Raster map shift - solved
Stefanie Weykam stefanie at weykam.net
Sun May 9 07:18:36 EDT 2010
A couple of weeks ago I notified strange raster layer behaviour and I
would now like to share with you how we solved the problem:
We observed a slight shift when the raster layer was displayed in
OpenLayers. The shift seemed to be dependent on scale and GetFeatureInfo
requests were not affected. That means that, although the pixel class
was not the expected one, the returned value was always correct. We did
not observe this behaviour in the thick client we use to check our map
services and therefore concluded that the underlying WMS was correct and
that the shift had something to do with how OpenLayers displays raster
layers.
And the end it turned out that the test client did not display the layer
correctly either – we just happened to look at a scale where the shift
was very small. So, OpenLayers was off the hook and we went back to
MapServer. We finally changed the configuration to allow non-square
pixels - the raster layer pixels are defined in decimal degrees and thus
are irregular.
For those who have been working for years with MapServer and didn’t even
know that this parameter existed, this did the trick:
CONFIG MS_NONSQUARE yes
According to the manual, this should be the default, but it seems that
MapServer doesn’t always ‘remember’ this.
Now everything is back in place. Thanks, Bart, for the hint.
Kind regards,
Stefanie
