[OpenLayers-Users] WMS request timeout during zoom/pan/resize
Heiko Schröter
schroete at iup.physik.uni-bremen.de
Tue May 11 04:30:18 EDT 2010
Am Dienstag 11 Mai 2010, um 10:23:51 schrieben Sie:
Hi Jon,
thanks for your reply. The raster images are so called "gridded" imeges of satellites measurements.
They have to be done globally and are created on the fly taken the data points from a PostGIS db.
Hence every zoom/pan/resize action triggers the data request and the creation of the "gridded" raster image.
That is the reason why i'am trying to delay the creation till the zoom/pan/resize interaction comes to an halt.
Thanks and Regards
Heiko
> Hi Heiko,
> How are you serving your WMS layers? Can't you just use tiling in
> OpenLayers and cache the tiles on the server (like GeoWebCache)? This
> should solve your resizing problems and your slow rendering...
> Jon
> On 11 May 2010 09:10, Heiko Schröter <schroete at iup.physik.uni-bremen.de>wrote:
> > Hello,
> > we have several WMS Layers some of which are expensive (in machine cycles)
> > to render raster images. We do observe that each time the Browser Window is
> > rezised or the user pans/zooms a WMS request is generated for every
> > zoom/pan/resize level.
> > Is there a possibility in OpenLayer to supress the rerendering or the newly
> > generated WMS requests till the zoom/pan/resize comes to a halt for certain
> > period of time ?
> > The situation now could bust the server if someone has a nervous hand on
> > the mouse ...
> > Thanks and Regards
> > Heiko
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
