[OpenLayers-Users] WFS maxFeatures
Balázs Bámer bamerbalazs at gmail.com
Wed May 19 07:26:14 EDT 2010
Hi Bart,
> Sure, perform a GetFeature request with resultType hits and you'll know.
Yes, I know but that would be 2 requests each performing a possibly
long dastabase operation. And it would require extra processing on the
client side. Well, this would be required only for the equal case...
Now I know the solution. I specify a somewhat higher limit and if the
result count reaches the limit, I cancel the result set even if it
would be the equal case.
best regards: Balázs
